http-analyze
      Enables HTTP URL analysis on the
         WLAN
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
            - Service Platforms:
      Syntax
         http-analyze [filter|syslog]
         http-analyze filter [images|post|query-string]
         http-analyze syslog host <IP/HOSTNAME> {port <1-65535>}
{proxy-mode [none|through-controller|through-rf-domain-manager]}
      Parameters
                     | filter |
                     Filters URLs, based on the parameters set, before forwarding
                        them |
                     | images |
                     Filters out URLs referring to images (does not forward URL requesting
                        images) |
                     | post |
                     Filters out URLs requesting POST (does not forward POST requests). This
                        option is disabled by default. |
                     | query-string |
                     Removes query strings from URLs before forwarding them (forwards
                        requests and no data). This option is disabled by default. |
                     | syslog host <IP/HOSTNAME> |
                     Forwards client and URL information to a syslog server
                           - host
                              <IP/HOSTNAME> – Specify the syslog server's IP address or
                              hostname
                     | port <1-65535> |
                     Optional. Specifies the UDP port to connect to the syslog server from 1
                        - 65535 |
                     | proxy-mode [none|through-controller| through-rf-domain-manager] |
                     Optional. Specifies if the request is to be proxied through another
                           device
                           - none – Requests are
                              sent directly to syslog server from device
                           - through-controller –
                              Proxies requests through the wireless controller configuring the
                              device
                           - through-rf-domain-manager – Proxies the requests through the local RF
                              Domain manager
         ap505-13403B(config-wlan-test)#http-analyze syslog host 10.234.160.4 port 21 proxy-mode
through-controller
         ap505-13403B(config-wlan-test)#show context
wlan test
 ssid test
 vlan 1
 bridging-mode local
 encryption-type gcmp256
 authentication-type eap
 dynamic-vlan-assignment allowed-vlans 2-4
 protected-mgmt-frames mandatory
 protected-mgmt-frames sa-query attempts 1
 use aaa-policy test
 http-analyze syslog host 10.234.160.4 port 21 proxy-mode through-controller
 controller-assisted-mobility
 dpi metadata http
